4057233002451
Výrobca: 101 octane
Kód: IP38460
€54,50 s DPH
Standard crankshaft in good quality as a spare part for Puch Maxi mopeds with E50 engine. This crankshaft is a replica of the old crankshaft model with a stronger collar for the crankshaft sealing ring. (enlarged seal ring 22x40x7). See detailed photo. This crankshaft uses crankshaft sealing rings 17x40x7 (left) and 22x40x7 (right) as well as a left crankshaft bearing 6203 (LAG.6203.C3) and right crankshaft bearing with 12mm inner ring. (LAG.6203.NR)
Výrobca skútra Puch
Model skútra Maxi S / N 1-Gang Automatik [E50] rechtsdrehend, Maxi P1 (Piaggio)
kľukový hriadeľ pre Puch Maxi (s E50 motor )
€54,50 s DPH
